Beta
Using Beta 7. Waveform progress bar on NPS (all kinds, as far as I can tell) works fine unless there is another item above it in the “row order” setting. If that happens (in my logs, I’m putting string 2 above the progress bar), the progress bar changes to the basic progress bar and does not change back until the progress bar is back to being the top item on the row order setting.
Plex
Using a NPS with the progress bar set to any waveform setting, open row controls and drag any string above the progress bar in the row order. So far this has worked 100% of the time for me, but some NPS styles seem to avoid this somehow.
This does not appear to be an issue with the preview, it looks totally fine there, only when handling actual data.
sodawars
