Automatic resampling to 48kHz / limiting max frequency
Limiting the max frequency like UAPP player
Hello.
First of all thank you for your work on this awesome player, the only one which actually enables me to stream my lossless collection from Pcloud without a hitch!
I search the documentation but to no avail : using UAPP player on android I can limit frequency by 48kHz. Why? Because I’m using AptX lossless with my bluetooth headphones and everything above that will default to Aptx Adaptative.
Is it possible on Symfonium? I only found a max bitrate setting.
useful for AptX lossless users
If you enable developer tools on your phone, you can probably go in and manually set the supported sample rate for the Bluetooth and then any apps should resample in order to work with that setting.
thanks for your suggestion!
I tried with 2 different pairs of earbuds connected to my phone’s bluetooth: everything is greyed out (not all the developpers options, just the frequency ones)
then I tried connecting them to an usb-c bluetooth dongle (to get aptx lossless on my phone which doesn’t have it normally), same result all the values greyed out
good try though :confused:
Hello Tolriq, I recently saw that it had been implemented, thank you! :slight_smile:
