Automatic downloads not downloading
Beta
My device had been offline for awhile whilst awaiting a replacement battery which meant once I updated it all my smart playlists had rotated.
After waiting for all the existing songs to be removed, I noticed a lot never redownloaded - I was expecting around 900gb of tracks to download but I only seem to be sitting around 200.
I’ve uploaded logs under talios and about to send a copy to my desktop to take a look myself (I suspect problems on my side with plex).
Mark
Plex
Sync… No auto downloads actually download (I see some show in the download queue, but they never download and just disappear from the queue)
I’m actually on a hiby r6 cap not a phone, but its android based
talios
Please send a short debug capture covering one sync and a track disappearing from the download queue without downloading.
The upload I found under talios contains only about 42 seconds and records an earlier log upload failing because it exceeded 100 MB. It doesn’t include the sync or download attempt, so I can’t tell what’s stopping the downloads yet.
Enable debug mode, reproduce that sequence, then disable debug mode and upload the logs promptly using this guide:
You don’t need to wait for the whole library to download. Reply with the upload description and the time the problem occurred so I can find the right capture.
About to submit a new log (under talios) that covers the sync and playlist sync ( for some reason this sync still took an hour ish, lots of tracks).
Syncing playlists started at 10:54 on 1 November - I have noticed that several of my playlistys (“Unplayed: added in the last day” is one) are listed in the media download page as having automatic downloads enabled, however when I look in the Playlists section of the app - that playlist is no longer showing.
I tried reimporting that playlist but it still doesn’t appear.
I remember having a similar issue years ago.
And interestingly, I just now spotted the playlist has returned and is downloading. I had run a “cleanup internal state” last night so maybe that fixed things?
