Audiobook chapters problem
The chapters in the audiobooks are missing. I tried using another audiobook player and they are visible there, but in Symfonium I cannot seem to see them. I usually use a cloud service where I store my books, but I also tried downloading the file locally and testing it, and the chapters are still missing. I also tested with older audiobooks that I have listened to before and I’m sure there were no issues with them - now I can’t see this option with them either. Do I need to enable some additional setting, or has the option been removed, or is this a bug?
Please assist. Thank you!
pCloud
When I start playing the file when press the button for chapters it shows me there is only one chapter.
Missing chapters
I need proper logs containing the start of the playback and then the opening of the chapter sheet.
I have sent you start log but I don’t know how send you when chapter option is opened…
I meant open the chapter button when logs are enabled. The logs does not seems to show the actual start thatt’s strange.
Upload the file to https://upload.symfonium.app so I can try to repro
I’ve sent logs (I hope the right logs) and the file.
Thanks will be fixed in next releae.
