Artist Bios not updating to current nfo info
I recently had symfonium sync all my artist nfos. I then made changes to some, but even after a resync, the bios remain unchanged.
Upload description: Bigmack3000
Should I clear artist info cache every time I want to resync that folder? Is that the way around this?
Sync an nfo folder. Change the info in some files. Sync again.
Yes you need to clear, too slow to scan all everytime and currently don’t have a way to detect changes on those.
What’s the proper steps for that? Because i tap “clear scraped artist info cache” but nothing seems to happen. There’s no cache cleared pop up, and no change on the next scan. Is there another step?
Thanks!
Nothing more to do. Provide logs doing just that and not your usual 1 GB log :wink:
Ha, i uploaded new logs. I restarted the app, clicked clear artist info cache, and ran a sync scan. That alone already hit 350mb, but they should be up now.
You are using LMS so Symfonium did not touch the NFOs …
If the data is correct on LMS side you need to clear the scraped data inside the provider settings.
Thank you! All fixed now.
