I’ve made two videos showing the problems I have and what i’d suggest is below.
1/ Left > Right behaviour - as you see in the video, when the Top Left button is selected and I then press the Right navigation on the remote, the normal behaviour is the selection would move Right. At present it moves Right but three rows down! Sometimes it moves right, other times Right and Down… The position of the highlighted button should determine where the R and L buttons target. They should be in horizontally identical positions, or as much as possible. This would make navigation very intuitive and clear.
https:// videoblurb dot com/mp/left-right-inconsistent.mp4
2/ Up > Down behaviour - as you see in the video, when scrolling down a list and getting to the bottom, you often find the highlight has disappeared from the list and is now highlighting some buttons on the Left. This should never happen. Either the highglight should stop at the bottom of the list and go no further until you give it a command that makes sense, like Up or Left, or the other way of dealing with it would be for the highlight to go from the bottom of the list to the top again, so it cycles through the list if you just kept pressing Down or kept pressing UP… so Up Down would never automatically to left or right. That makes navigation very messy and confusing.
https:// videoblurb dot .com/mp/navigation-down-up.mp4
My request is to please keep L-R separate from U-D so that navigation is visually predictable. Thanks!!
Confusion from navigation that is unexpected and difficult to follow or understand.
Clear and simple, universally understood left right up down movements that are visually satisfying as they are predictable.
Android TV
