Android TV Layout issues
I was playing around with the Android TV layout settings. I selected the bottom floating bar with the fab.
The floating bar is not present on the screen. Neither is anything that’s currently playing. If I play a new song the bar will flash at the bottom of the screen for half a second then disappear. I can no longer access the settings or anything else within the app, nor can I access any playback controls.
I know we’re supposed to have logs, but I couldn’t access them if I wanted to. Do I need to just uninstall and reinstall the app?
Android TV
  1. Interface
  2. Navigation
  3. Landscape style
  4. Bottom floating toolbar
N/A
Normally you have access to the settings via the OS Application page there’s a button.
Else yes you need to reinstall, there’s still a couple of phone only settings that can be enabled in Android TV builds.
