Always replace playlist when syncing... now being prompted
Not sure what changed recently for this specific behaviour (possibly related to fixes regarding my large plex library syncing), but recently when I sync the playlist, I get prompted to either push or pull it to/from the server - this was originally a read-only imported playlist (ok, plex smart playlist, but yeh) - is there any way to get this back to always replacing?
See: Dropbox
Upload description: talios
For some reason lately I’ve noticed I can’t import new playlists from Plex.
  • Click import
  • Select either offline first, or read only
  • select the playlist you want to import (this is a smart play, sue me)
  • symfonium just sits there saying “importing” and does nothing until I touch the screen and the “importing” message goes away
  • no new playlist appears on my list of imported ones
Plex
Erk, somehow I ended up commenting on this earlier support ticket. Have raised a new issue for this playlist import issue.
You probably clicked on the button to remove read only.
There’s no way to return to read only. You just import the playlist again, enable offline caching is it was present then delete the older one.
Do not delete the wrong one first if you have auto sync on it to avoid unwanted item removal from offline cache.
