Allow for more constraint types on smart playlists mood filter
Currently you can create a smart playlists and mood is a supported tag you can filter on, however it only allows for a specific equality based match.
I would request the mood filter works similar to genre filter (as an example) where it can support not just equality but partial matches via contains, and if the tag is present at all.
This would allow for filtering on one or more matching moods where mood tags contain multiple values, i.e sorrow, calm or tense, exciting
Currently a file with multiple moods could not be filtered by a single (or multiple) mood/s using the equality match.
It allows for more flexibility in creating smart playlists.
N/A
N/A
