Currently, the progress and volume bars take the primary color, but their appearance cannot be customized. I would like to see additional styling options similar to those used for the control button bar icons (Default, Lower Emphasis, Primary Color, Lower Emphasis Primary Color).
This customization should apply to both segments of the bars:
- For the progress bar, users could independently set colors for the played and unplayed sections.
- For the volume bar, users could set different colors for the filled and unfilled portions.
For example, in my current setup (1st attached screenshot), the progress and volume bar consists of a brown (primary color) and purple (default theme color) combination. I would like to be able to change the unshaded portion (purple) to lower emphasis primary color for better visual consistency.
Adding this flexibility would provide more control over UI aesthetics
More dynamic elements which can better match a user’s theming
The first screenshot shows the current state
The other screenshots show the wanted future state
