Album images in albums view
Please assist with troubleshooting missing album artwork on multiple albums.
Music is arranged into folders for each artist and subfolder for each album.
All album folders have cover.jpg files and album artwork is shown for all albums in Navidrome.
All tracks have embedded artwork.
I can refresh the artwork per album by removing cached images in album view and restarting Symfonium. This is not practical as I have so many albums not showing album art that this would take days of repetitive actions.
Logs uploaded with nickname Cressbrookian.
Many thanks, love the app!
Navidrome
Open album view.
Scroll down.
Cressbrookian
You can clear all cached artwork at once in Settings > Advanced settings > Clear image cache. Then restart Symfonium and browse your albums while connected to Navidrome. The images will download again on demand.
If covers are still missing, please send a focused debug log using this guide. Enable debug mode, open the album list and scroll to an affected album without starting a library sync. Then disable debug mode and upload the logs promptly. Reply with the upload description, the time the problem occurred and one affected album’s name so I can match it to the log.
Many thanks. Uploaded log of scrolling to A Different Kind Of Fix by Bombay Bicycle Club. Also Dig Lazarus Dig! By Nick Cave & The Bad Seeds.
Upload is named Cressbrookian.
Deleted image cache, restarted then scrolled.
The new log shows the image cache being cleared, followed by artwork being downloaded, decoded and cached successfully. I don’t see any image-download failures in this recording.
Check that fetch additional metadata is enabled and try to clear scrapped data in the provider settings too.
Thanks again. I’ve tried as you suggest again but with no joy. I’ve been through laboriously deleting caches per album. I hope that they stick now!
Can you advise optimal settings to preserve the now corrected album images files?
I’ve backed everything up but unsure if this is what I need.
Many thanks for your time.
Not sure what you mean here, what cache? There’s no setting
Sorry. ‘Remove cached images’ from the Album menu ( three dots on the right on the Album page on my app Album view).
This does nothing more than the clear image cache in advanced settings so there’s something else here.
Install v16 beta it will show exactly image cache size to confirm the clear works
Will do. The practical effect of removing the cached images files is that the album image is refreshed and appears correctly after restarting the app.
The clear image cache in advanced settings clear all images. So what you explain is strange.
Sorry if I’ve not been clear. I did use the clear image cache in advanced settings to clear all images some time ago. At the moment though, I’m talking about the three dot menu on the album view that gives a menu option to ‘Remove cached images’ for that album. That is the only way I’ve found that apparently allows a ‘refresh’ of the album image so that, after a restart of the app, the album image displays correctly instead of the default blue icon. The album image starts blue until a restart when it appears correctly.
I did understand;) Look like you missed the message about clear scraped data inside the provider then ?
Yes, I also did a full refresh of metadata in Navidrome before clearing the cache in Symfonium Advanced Options. It didn’t appear to have any effect. Even after the Symfonium sync had run through, the same album covers were missing.
Again : Clear scraped data in the provider settings
Yes, I have done that but after downloading new metadata to navidrome the album covers issue persisted.
If Navidrome does not return the artwork as a normal artwork but only via the extended ones, then you need to clear scraped data each time yes that’s expected.
