Background: I edit and tag my locally owned music on my PC using MusicBrainz, then transfer it to my phone. Everything used to work smoothly, but recently I’ve run into a strange issue with album art. The album art I embed shows up in some places, but not others, and I haven’t found any pattern or consistency to it.
Here’s the behavior I’m seeing:
The cover art does not show up in the preview/thumbnail display — instead, my phone defaults to some unrelated image it already has stored.
The cover art does show correctly on the Now Playing screen.
I’ve saved the files multiple times with the correct embedded cover, both as local cover art and as the primary image in MusicBrainz, and the issue still occurs.
Here are the exact scenarios that I can reproduce with 100% consistency:
Scenario that works:
I transfer the edited music to my phone.
I open my music app and view the tracks.
On the Now Playing screen, the correct album art always shows.
Scenario that doesn’t work:
I browse the music in any preview list or library grid.
The album art thumbnails frequently default to a totally unrelated image stored on my phone.
Re-saving or re-embedding the cover art doesn’t fix the thumbnails, even though the Now Playing screen continues to show the correct art.
I’d describe this as more of a nuisance than a breaking issue, but it’s definitely annoying, especially when I took the time to pick out the artwork I wanted.
Has anyone else run into something like this? Is there any rhyme or reason behind why thumbnails pull a random image while the Now Playing screen uses the correct embedded art?
Upload description: thegoldmolar
- Opening the app fresh
- Fresh sync and app update
- Click open new tracks that have cover art added via musicbrainz from my pc that typically is saved and reflected in the app
- Press play on the track that defaults to the a different cover on the preview cover art section and notice on the play now has the actual intended cover art.
