I used Musicbrainz Picard to tag. The name of it is incorrect along with no artwork. I had this issue a while ago, but it was due to MB size. Here, I made sure to reduce but still the same issue.
I made sure to clear cache and image cache to no fix.
The logs contain two album names for each single. For example, 2000 - The Hollow [CD Single] comes before The Hollow, and Symfonium uses the first value. The sync reused cached tags.
Once your edited files are fully uploaded to pCloud, use Clear tag cache in the pCloud provider settings, then sync again. This makes Symfonium read the tags again and will rescan all files from that provider.
Artwork extraction is also failing for both singles, but the logs don’t establish why. Please upload one affected FLAC downloaded from pCloud to https://upload.symfonium.app. Add nov2-artinfo and a short description of the problem so I can identify it.
