Album art constantly having to reload on tablet; works fine on phone
Symfonium running on Galaxy Tab s8+ keeps deleting persistent image cache. It’s constantly having to reload images. I run the same exact library on a Galaxy S25U and it works just fine. The only difference is that the phone is streaming from SMB share, whereas the tablet downloads everything from SMB share to micro SD card. Same library settings, same app permissions, unrestricted battery, same Android version (16) and One UI version (8.5), etc. Log uploaded; Appreciate any advice
SMB
  1. Open app, all images on the home page slowly load in
  2. Go to albums page, all images start as black and slowly load in while scrolling down. When returning to the top, sometimes images are still retained and load instantly, sometimes they’ve already been purged and have to slowly reload
  3. Repeat
  4. Suffer
trufflebags
Thank you for reporting this. I found your upload, which already shows 15.1.0, the current production release.
I can’t confirm cache deletion from this capture. Persistent image cache keeps artwork files on disk; images can still need to be read and decoded again after they leave memory. When enabled, the artwork cache uses an images folder under the selected offline storage location, so SD-card read speed could affect this, but I haven’t established that as the cause.
Please confirm whether “Persistent image cache” and “High quality images” are enabled, and your tablet model: the log reports SM-X820.
Could you please capture the complete sequence using the debug log guide? Enable debug mode, fully close and reopen the app, let the home images load, then scroll down the albums and return to the same covers until the delay happens. Disable debug mode and upload promptly, and reply with your app version, upload description and the occurrence time. This will help me check the cache location from startup and correlate it with the delay.
Hi again,
Thanks for your quick response! I did have the tablet model incorrect, it’s a Galaxy Tab S10+. I just uploaded a new log. I’ve been recreating the problem over and over. It’s very quick to wipe the image cache without me having to do much. I don’t see any evidence of this in the log, though. Persistent image cache is On, and High quality images is On. If this is all the result of the SD card being slow, is it possible to choose an internal location for image cache? Thanks!
Thank you for the new log and the clarification. I still don’t see evidence of the image cache being deleted. The log doesn’t record every cached-image read or decode, so it can’t establish the cause of the delay.
With “High quality images” enabled, cached artwork uses larger lossless images. Reading and decoding these from an SD card could contribute to the delay. There isn’t currently a separate storage selector for persistent artwork: the storage setting also controls music downloads.
For a useful comparison, please turn off “High quality images,” keep “Persistent image cache” on, and use Settings > Advanced > Clear image cache once. This removes cached artwork, which must reload from your SMB share; it leaves downloaded music intact. Let the clearing finish, fully close and reopen the app, load the same few album covers while connected to the share, then scroll away and revisit them. Please compare the second visit, after the initial refill.
If it still happens, please share a short recording and debug logs covering that comparison, with debug mode enabled before clearing/restarting. Include the occurrence time, app version and upload description so I can correlate them.
Hi again,
Thanks for your response. Just uploaded new logs, but you’ll probably see everything is working as it should:
I unchecked ‘High quality images’, and the images are now staying loaded all the time. This is great, but now the art is low quality on a big, high quality screen. I spend a painstaking amount of time getting the best album art for my collection, and now it presents poorly. So I think a solution would be to allow us to customize the location of the persistent image cache, or let us download low quality thumbnails that stay loaded, and high quality artwork that can take a moment longer to reload once we select an album. Could this thread count as a feature request, or should I make a new thread under Feature requests?
Open a request for different storage for offline music and image cache, but they do take a lot space at max quality.
