When using the single line rows toggle id like for each row to have a dropdown / expand option similar to how the album description can be expanded via the “Show more” text
Some of my tag fields hold alot of tags. In album view it can be advantageous to shrink those tags to one line you can scroll through horizontally. This can save you from needing to scroll very far vertically in the album page.
The downside is when you do one to view one of those fields with alot of tags the horizontal scrolling can be just as tedious.
Users could now show one line for all tags & then expand a specific field If & when they’d like to see more of those tags.
This I believe gives a good middle ground to the two current options for displaying the about rows in album view.
With this implementation users can sort of hop & skip over some fields & dive into others while also negating alot of extra scrolling
I think a small flipped “^” in line with each tag header could be a clean way to implement this
Ex:
Genres____________^
