I do like dsubs caching method.
When playing songs it automatically builds a cache with a configurable max size by downloading the current song and the next three.
When the cache size is reached, the oldest song gets deleted.
This greatly increases reliability in regions with bad mobile internet, like Germany, or when driving through tunnels.
But to resume again, the issue is about the cache limit and auto prune.
Symfonium is offline first with many cache functions and auto cache functions those functions requires that the data is not purged as the user expect the data to be here when they need it.
Having a playback cache only makes little sense due to that. Automatic pre caching is not an issue, but without a limit it can cause storage issues.
I currently do not have a proper UI/UX solution to address properly all the cases, usually users create playlists and enable auto cache on them.
Using (smart) playlists would require me to plan ahead what music I would like to listen before getting in the car. But usually I get in the car, select a random album and listen to that.
Caching during Playback helps getting through bad connections and also reduces data usage when listening to the same album multiple times.
Maybe this option can be seen as a different / additional caching option to the current caching option
This is not that simple to have 2 levels of caching with different kind of transcoding profiles and many parameters.
While a small preload cache different from the rest can makes sense, having a large one to reduce data usage a lot less with all the auto cache features.
Next version will have a playback cache with preloading.
This cache will be 100% independent from the offline cache so should not be used for such usage, there’s no guarantee that content will still be present and usable between sessions and application updates.
Can I follow-up on this topic? I often walk around university buildings, where wifi reach (eduroam) might be patchy. This means the playback from Symfonium stops once in a while, whenever the device is successful connecting from mobile network to wifi and backwards.
Can you please suggest how to avoid these playback interruptions, while walking in areas with wifi/mobile data exchange? DSub’s solution was quite elegant, that
one was able to set a song-cache for 2-3 songs
if the player had already a song downloaded, it played it from cache
if not, it tried to download it from the accessible connection, and automatically resume whenever the connection changed
Isn’t playback cache a bit too much? I mean the lowest value is 128MB. I want to have pre-cached only 3 songs, not 128MB. With that amount I can easily use all my data… Or does this work progressively, that the max cache is 128MB (if set), and it always pre-loads the next song only?
