Allow the user to toggle the “String _ ellipsis” setting between “None” or “End ellipsis” and “Marquee” as a String template click action.
For long strings, such as composer for a song with a large number of composers, it’s unsightly to have the long list constantly scrolling across the screen, as it does when you select “Marquee” as the “String _ ellipsis” option. However, if you select “None” or “End ellipsis”, there’s no way to see the full string.
I would like to be able to toggle the ellipsis setting as a string template click/long click action, so that I can normally have the “End ellipsis” setting enabled but also click or long click to switch to the “Marquee” setting if I want to see the full string.
Better looking now playing screen while preserving access to full display string on demand.
