Ability to exclude tracks based on duration
Not sure if this feature exists or if it’s been requested already (search results were pretty lengthy, sorry if it was). I know this is an option with smart playlists, but it would be nice to have the ability to exclude tracks from standard mixes based on duration, since these are the mixes I typically choose, especially when using Android Auto. I have a lot of tracks in my library that are less than 10 seconds long that’s just going to throw off valid over all play count times if I’m unable to change the track in time before it ends.
Play count / “favorites (according to Symfonium)” validity
Excluding a song that’s only a few seconds long, deleting them from a library wouldn’t be ideal since they’re apart of actual released albums
Only other solution I can think of is to remove them from the library by deleting them, which would not be ideal.
