14.0.0B2 NPS - Force Light/Dark Mode
Force all colors to be selected from chosen theme mode.
Specifically in regards to Primary/Tertiary colors.
“Force black overlay” does not influence the selection of Primary colors.
Primary colors selected in Light Mode are still much darker than in Dark Mode, despite being displayed on the same color overlay. This often causes contrast issues.
Light Mode’s Tertiary color is applied on top of the now-black overlays, which may cause contrast issues.
Allows NPS to use the same colors regardless of current Light/Dark mode selection.
Pic 1: Primary colors in Dark Mode. Mostly legible. (Force black is off but only difference is darkness of overlay.)
Pic 2: Primary colors in Light Mode with “Force Black Overlays” enabled. Barely legible.
Pic 3: Primary colors in Dark Mode, Force Black enabled
Pic 4: Primary colors in Light Mode, Force Black enabled
The themes are not aware of their other counter parts and the app have no way to know if you will display the primary color over an overlay or not.
With so many options, yes some cases won’t look perfect, but that’s the price of liberty.
Totally fair. Thanks for the response!
