14.0.0B1 - NPS - Tertiary Color misapplied on Bottom Bar
The Bottom Bar does not correctly handle the “Theme tertiary container” color option.
Setting this color on buttons 2-7 has no effect at all.
Setting this color on button 1 correctly sets this button to the tertiary color.
It also replaces the “Default” color with the tertiary color for all other buttons.
Upload description: Celorien_NPS_Tertiary
I didn’t go crazy testing combinations, but all other NPS elements are able to set Tertiary color correctly. Only the “Bottom bar” is affected.
Set theme’s “Tertiary container” color to an identifiable color. Edit an NPS layout, any orientation. Under “Bottom Bar” set at least Icon 1-3 with any action. Set icon 1 to Default color, icon 2 to tertiary, and icon 3 to primary. Tap Preview:
Icon 1 and 2 will be the Default color, icon 3 will be Primary color.
Now set icon 1 to tertiary color and tap Preview:
Icon 1 and 2 will be tertiary color, icon 3 still Primary
Now set icon 2 back to Default color and tap Preview:
Icon 1 and 2 are still tertiary color, icon 3 still Primary
