That still doesn’t help, since it was already active. Changing to “Theme trrtiary container” does do the trick. Still think it should follow the “default” color that the other text follow.
The inverted overlay and protection color option just changed the focus from the Dark theme to the light theme (Inverting the colors does invert the problem xD)
The only option I am changing are: String 3 color, String 1 icon 1 color and String 1 icon 2 color
These is the theme with Tertiary Color applied (set to white over white text for both), “Inversted overlay and proteciton colors” does not change anything, since they are both white.
Dark Theme - White Theme
Could you add the force black overlay color for the these parts? It wouldn’t touch the color of the icon, but at least the overlay/protection would look the same in both Light and Dark theme.
