14.0.0B1 Cover String opacity when playing
You know how the four corner-icons on the cover art have the option to become very transparent while playing? And then reappear when paused?
I would love if the new cover strings could hook into that, so they don’t block the art while media is playing.
The new strings have static opacity. If set, they are always visible on top of the art.
Allows for clean UI while media is playing with extra data shown when paused.
I intend to use this to show the rating over the art.
I can also see it being used for showing something like Skip Count. Just paused, and you’re about to skip the song again? String showing: “99 Skips” will pop up and make you feel guilty about it lmao.
Lmao love it though, thanks!
